Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic
Reload this Page >
Diesel and 2-stroke oil in Swiwin?
Turbine Clinic Get direct support from the major turbine manufacturer support reps in here.
Old 04-16-2024, 04:13 PM
SpringPulse92
Default Diesel and 2-stroke oil in Swiwin?
I have about 15 gal of diesel and two-stroke oil mixed in a 50:1 ratio left over from a previous Jetcentral turbine I've recently sold. The Swiwin calls for diesel and 3% turbine oil for lubrication rather than two-stroke oil. I wondered if I could reuse that diesel & two-stroke mix on the Swiwin turbine. The methods I'm considering are as follows:
1. Use mixture as is.
2. Add more two-stroke oil to achieve a 5% lubrication ratio.
3. Add turbine oil to the existing mixture.
What is everyone's take on what I should do?
Old 04-16-2024, 04:42 PM
Maveric168
Default Swiwin turbine
I would not mix 2 stroke oil with diesel gas. You can void the warranty by doing so. An if you got that more from CRX turbine usa, then I definitely would not do it. Because they can tell.
Old 04-16-2024, 04:44 PM
SpringPulse92
I should mention that the Swiwin is used and not covered by warranty.
